ich kann zwar jack starten
allerdings findet muse keinen jack server ...[root@linux booker]# jackd -d alsa -d hw:0 &
[2] 15928
[root@linux booker]# jackd 0.34.0
Copyright 2001-2002 Paul Davis and others.
creating alsa driver ... hw:0|1024|2|48000|swmon
ist etwas mit den von mir verwendeten jack optionen faul?[root@linux muse]# muse &
[1] 15981
[root@linux muse]# Loading required GL library /usr/X11R6/lib/libGL.so.1.2
no locale <muse_en_US>/</usr/local/share/muse/locale>
no JACK audio server found
name2Node failed <Track 2>
Mess: MidiThread set to SCHED_OTHER priority 60
create Synth instance <fluidsynth-1> channels 2 2
create Synth instance <vam-1> channels 1 1
ALSA lib pcm_hw.c:866:(snd_pcm_hw_open) open /dev/snd/pcmC0D0c failed: Device or resource busy
ALSA: device <hw:0> open error: Device or resource busy
