> General setup > RCU Subsystem > Enable RCU priority boostingAuf welchen Wert habt ihr ihn gestellt?
z.b.
CONFIG_RCU_BOOST_PRIO=99Code: Alles auswählen
CONFIG_RCU_BOOST_DELAY=331Code: Alles auswählen
.config - Linux/x86 3.18.2-gentoo Kernel Configuration
> General setup > RCU Subsystem ──────────────────────────────────────────────
┌───────────────────── Enable RCU priority boosting ──────────────────────┐
│ CONFIG_RCU_BOOST: │
│ This option boosts the priority of preempted RCU readers that │
│ block the current preemptible RCU grace period for too long. │
│ This option also prevents heavy loads from blocking RCU │
│ callback invocation for all flavors of RCU. │
│ Say Y here if you are working with real-time apps or heavy loads │
│ Say N here if you are unsure. Code: Alles auswählen
┌────────────── Real-time priority to boost RCU readers to ───────────────┐
│ CONFIG_RCU_BOOST_PRIO: │
│ This option specifies the real-time priority to which long-term │
│ preempted RCU readers are to be boosted. If you are working │
│ with a real-time application that has one or more CPU-bound │
│ threads running at a real-time priority level, you should set │
│ RCU_BOOST_PRIO to a priority higher then the highest-priority │
│ real-time CPU-bound thread. The default RCU_BOOST_PRIO value │
│ of 1 is appropriate in the common case, which is real-time │
│ applications that do not have any CPU-bound threads. │
│ Some real-time applications might not have a single real-time │
│ thread that saturates a given CPU, but instead might have │
│ multiple real-time threads that, taken together, fully utilize │
│ that CPU. In this case, you should set RCU_BOOST_PRIO to │
│ a priority higher than the lowest-priority thread that is │
│ conspiring to prevent the CPU from running any non-real-time │
│ tasks. For example, if one thread at priority 10 and another │
│ thread at priority 5 are between themselves fully consuming │
│ the CPU time on a given CPU, then RCU_BOOST_PRIO should be │
│ set to priority 6 or higher. │
│ Specify the real-time priority, or take the default if unsure. │
┌────── Milliseconds to delay boosting after RCU grace-period start ──────┐
│ CONFIG_RCU_BOOST_DELAY: │
│ This option specifies the time to wait after the beginning of │
│ a given grace period before priority-boosting preempted RCU │
│ readers blocking that grace period. Note that any RCU reader │
│ blocking an expedited RCU grace period is boosted immediately. │
│ Accept the default if unsure. │
http://www.rdrop.com/users/paulmck/RCU/
