habe - mal wieder - prob mit jack. Bekomme xruns wenn ich jack starte ohne das irgendein jack-programm laeuft.
Jack lief schonmal gut mit "Latency 5.33 msec". Nach evt. "apt-get install *audio-tools*" haben die xruns eingesetzt, reine Vermutung.
Habe Sidux nach der Wiki eingerichtet.
http://sidux.com/index.php?module=pnWik ... udiostudio
Die Hartware: AMD Athlon(tm) XP 2000+, 1G RAM, M-Audio Delta 1010LT
:~$ infobash -v3
Host/Kernel/OS "eris23LAW" running Linux 2.6.24-2.6.24.4.makke-rt4.2-sidux-686 i686 [ sidux 2007-04.5 - Έρως christmas special - kde-lite - (200712260129) ]
CPU Info AMD Athlon XP 2000+ 256 KB cache flags( sse ) clocked at [ 1662.080 MHz ]
Videocard nVidia NV34 [GeForce FX 5200] X.Org 1.4.0.90 [ 1280x1024@60.0hz ]
Network cards VIA VT6102 [Rhine-II], at port: e400
Processes 126 | Uptime 4:27 | Memory 383.4/1005.3MB | HDD SAMSUNG SP2014N,SAMSUNG SP2014N Size 400GB (36%used) | Client Shell | Infobash v3.01
:~$ uname -r
:~$ cat /proc/sys/kernel/kernel_preemption
1
:~$ cat /proc/driver/rtc
rtc_time : 22:11:15
rtc_date : 2008-03-30
rtc_epoch : 1900
alarm : **:45:**
DST_enable : no
BCD : yes
24hr : yes
square_wave : no
alarm_IRQ : no
update_IRQ : no
periodic_IRQ : no
periodic_freq : 1024
batt_status : okay
:~$ lspci -v
00:0b.0 Multimedia audio controller: VIA Technologies Inc. ICE1712 [Envy24] PCI Multi-Channel I/O Controller (rev 02)
Subsystem: VIA Technologies Inc. M-Audio Delta 1010LT
Flags: bus master, medium devsel, latency 32, IRQ 20
I/O ports at a000 [size=32]
I/O ports at a400 [size=16]
I/O ports at a800 [size=16]
I/O ports at ac00 [size=64]
Capabilities: <access denied>
Kernel driver in use: ICE1712
Kernel modules: snd-ice1712
:~$ cat /proc/interrupts
CPU0
0: 980062 IO-APIC-edge timer
1: 2240 IO-APIC-edge i8042
3: 1 IO-APIC-edge
4: 1 IO-APIC-edge
6: 2 IO-APIC-edge floppy
7: 0 IO-APIC-edge parport0
8: 2 IO-APIC-edge rtc
9: 1 IO-APIC-fasteoi acpi
12: 171770 IO-APIC-edge i8042
14: 16565 IO-APIC-edge ide0
15: 58146 IO-APIC-edge ide1
16: 0 IO-APIC-fasteoi sata_via
17: 0 IO-APIC-fasteoi uhci_hcd:usb1, uhci_hcd:usb2, uhci_hcd:usb3, uhci_hcd:usb4, ehci_hcd:usb5
18: 66791 IO-APIC-fasteoi eth0
19: 0 IO-APIC-fasteoi VIA8237
20: 34875 IO-APIC-fasteoi ICE1712
NMI: 0 Non-maskable interrupts
LOC: 1773132 Local timer interrupts
RES: 0 Rescheduling interrupts
CAL: 0 function call interrupts
TLB: 0 TLB shootdowns
TRM: 0 Thermal event interrupts
SPU: 0 Spurious interrupts
ERR: 0
MIS: 0
:~$ ps -e -o pid,cmd,pri | grep IRQ
58 [IRQ-9] 90
262 [IRQ-8] 90
285 [IRQ-12] 90
286 [IRQ-1] 90
548 [IRQ-6] 90
677 [IRQ-14] 90
678 [IRQ-15] 90
679 [IRQ-16] 90
682 [IRQ-17] 90
1363 [IRQ-19] 90
1382 [IRQ-7] 90
1511 [IRQ-20] 90
2182 [IRQ-18] 90
2442 [IRQ-4] 90
2444 [IRQ-3] 90
4548 grep IRQ 19
:~$ ps -mo pid,cmd,pri -C jackd
PID CMD PRI
AC@AB:~$ ps -mo pid,cmd,pri -C jackd
PID CMD PRI
4570 /usr/bin/jackd -R -P89 -p12 -
- - 19
- - 19
- - 19
- - 19
- - 129
:~$ cat /etc/modules |grep snd
snd_via82xx
snd_ice1712
:~$ cat /etc/security/limits.conf |grep @audio
@audio - rtprio 90
@audio - nice -5
@audio - memlock unlimited
#@audio - memlock 750000
:~$ groups
khz dialout cdrom floppy audio dip video plugdev users fuse scanner powerdev netdev
:~$ id
uid=1000(khz) gid=1000(khz) Gruppen=20(dialout),24(cdrom),25(floppy),29(audio),30(dip),44(video),46(plugdev),100(users),101(fuse),104(scanner),110(powerdev),112(netdev),1000(khz)
:/# hdparm -d /dev/hda
/dev/hda:
using_dma = 1 (on)
:~$ cat .jackdrc
/usr/bin/jackd -R -P89 -p128 -t2000 -u -dalsa -r48000 -p128 -n2 -D -Chw:1 -Phw:1 -s -m -H -M -I1 -O2
20:57:18.494 Startup script...
20:57:18.495 artsshell -q terminate
20:57:18.933 Startup script terminated with exit status=256.
20:57:18.935 JACK is starting...
20:57:18.937 /usr/bin/jackd -R -P89 -p128 -t2000 -u -dalsa -r48000 -p128 -n2 -D -Chw:1 -Phw:1 -s -m -H -M -I1 -O2
20:57:18.958 JACK was started with PID=4642.
jackd 0.109.2
loading driver ..
apparent rate = 48000
creating alsa driver ... hw:1|hw:1|128|2|48000|0|0|hwmon|hwmeter|soft-mode|32bit
control device hw:1
configuring for 48000Hz, period = 128 frames (2.7 ms), buffer = 2 periods
ALSA: final selected sample format for capture: 32bit little-endian
ALSA: final selected sample format for playback: 32bit little-endian
cannot use real-time scheduling (FIFO at priority 99) [for thread -1228854384, from thread -1228854384] (1: Operation not permitted)
delay of 5328.000 usecs exceeds estimated spare time of 2647.000; restart ...
20:57:21.069 Server configuration saved to "/home/khz/.jackdrc".
20:57:21.071 Statistics reset.
20:57:21.075 Client activated.
20:57:21.083 JACK connection change.
20:57:21.115 JACK connection graph change.
20:57:22.561 XRUN callback (1).
delay of 12836.000 usecs exceeds estimated spare time of 2586.000; restart ...
20:57:24.187 XRUN callback (2).
delay of 5298.000 usecs exceeds estimated spare time of 2577.000; restart ...
delay of 5309.000 usecs exceeds estimated spare time of 2577.000; restart ...
20:57:25.094 XRUN callback (1 skipped).
20:57:25.383 XRUN callback (4).
delay of 12366.000 usecs exceeds estimated spare time of 2573.000; restart ...
20:57:25.581 Client deactivated.
20:57:25.583 JACK is stopping...
jack main caught signal 15
no message buffer overruns
20:57:25.624 JACK was stopped successfully.
20:57:25.625 Post-shutdown script...
20:57:25.626 killall jackd
jackd: Kein Prozess abgebrochen
20:57:26.039 Post-shutdown script terminated with exit status=256.
Jede Hilfe, jeder Tip ist willkommen
thx
