Knaeby
Beitrag von Knaeby »
Hallo corresponder+khz,
Ist das jetzt richtig, und was ist bei mir installiert worden? Ein Echtzeitkernel?
hans@hans-System-Product-Name:~$ cat /etc/security/limits.conf
# /etc/security/limits.conf
#Each line describes a limit for a user in the form:
#<domain>        <type>  <item>  <value>
#Where:
#<domain> can be:
#        - a user name
#        - a group name, with @group syntax
#        - the wildcard *, for default entry
#        - the wildcard %, can be also used with %group syntax,
#                 for maxlogin limit
#        - NOTE: group and wildcard limits are not applied to root.
#          To apply a limit to the root user, <domain> must be
#          the literal username root.
#<type> can have the two values:
#        - "soft" for enforcing the soft limits
#        - "hard" for enforcing hard limits
#<item> can be one of the following:
#        - core - limits the core file size (KB)
#        - data - max data size (KB)
#        - fsize - maximum filesize (KB)
#        - memlock - max locked-in-memory address space (KB)
#        - nofile - max number of open files
#        - rss - max resident set size (KB)
#        - stack - max stack size (KB)
#        - cpu - max CPU time (MIN)
#        - nproc - max number of processes
#        - as - address space limit (KB)
#        - maxlogins - max number of logins for this user
#        - maxsyslogins - max number of logins on the system
#        - priority - the priority to run user process with
#        - locks - max number of file locks the user can hold
#        - sigpending - max number of pending signals
#        - msgqueue - max memory used by POSIX message queues (bytes)
#        - nice - max nice priority allowed to raise to values: [-20, 19]
#        - rtprio - max realtime priority
#        - chroot - change root to directory (Debian-specific)
#*               soft    core            0
#root            hard    core            100000
#*               hard    rss             10000
#@student        hard    nproc           20
#@faculty        soft    nproc           20
#@faculty        hard    nproc           50
#ftp             hard    nproc           0
#ftp             -       chroot          /ftp
#@student        -       maxlogins       4
# End of file
@audio      -   memlock      unlimited
bei den nachfolgenden Befehlen sieht das Ergebnis so aus.
hans@hans-System-Product-Name:~$ #Each line describes a limit for a user in the form:
hans@hans-System-Product-Name:~$ #@student        -       maxlogins       4
hans@hans-System-Product-Name:~$ @audio      -   memlock      unlimited
@audio: Befehl nicht gefunden.
Ich werde mich mit den Internetseiten beschäftigen und melde mich wieder. Erst einmal vielen Dank, dankbare Grüße Knaeby
Knaeby
Hallo Correponder + khz,
die Internnnetseiten sind sicher hilfreich und ich werde sie immer wieder kontaktieren. Im Augenblick bekomme ich nicht mal Jack über Cadence konfiguriert. Dasi ist das nächte Nadelöhr damit ich wieder anfangen kann zu arbeiten. Wenn ich Cadence aufrufe und Jack starte bekomme ich diese Fehlermeldung.
Failed to start JACK, please check the logs for more information
Ich habe alle möglichen Einstellungen getestet, immer die selbe Meldung. Nach der Installation von kxstudio bestand kurz das Problem nicht. Wo sind bei Cadence die Meldungen versteckt? Ich finde sie nicht sonst hätte icch sie euch gepostet.
Ist dieser Schritt jetzt dran?
Grüße Knaeby
Knaeby
Hallo Corresponder + khz,
ich habe die Fehlermeldung für Jack in Cadence gefunden.
Mon Sep  7 23:33:30 2015: Starting jack server...
Mon Sep  7 23:33:30 2015: JACK server starting in realtime mode with priority 10
Mon Sep  7 23:33:30 2015: self-connect-mode is "Don't restrict self connect requests"
Mon Sep  7 23:33:31 2015: ERROR: cannot register object path "/org/freedesktop/ReserveDevice1/Audio2": A handler is already registered for /org/freedesktop/ReserveDevice1/Audio2
Mon Sep  7 23:33:31 2015: ERROR: Failed to acquire device name : Audio2 error : A handler is already registered for /org/freedesktop/ReserveDevice1/Audio2
Mon Sep  7 23:33:31 2015: ERROR: Audio device hw:Omega,1 cannot be acquired...
Mon Sep  7 23:33:31 2015: ERROR: Cannot initialize driver
Mon Sep  7 23:33:31 2015: ERROR: JackServer::Open failed with -1
Mon Sep  7 23:33:31 2015: ERROR: Failed to open server
Diese Fehlermeldung kam:
wie cofiguriere ich Jack ?  Im Augenblick  ist Input und Output Device  auf < hw Omega,1 ( USB Audio )  unter  < Duplex Mode+ Hadrware Metering > gestellt.
Es muss noch irgend was im "Untergrund" eingestellt werden damit Jack läuft, vermute ich.
Ich hoffe Ihr könnt mir jetzt weiter helfen.
Gute Nacht und Grüße Knaeby
Knaeby
wer hat von Euch Erfahrung wie Ardour 4 mit Midi in kxstudio eingerichtet wird? Mit Audio kann ich arbeiten aber nicht mit Jack in Cadence. Brauche ich Cadence überhaubt, Ardour arbeit wohl auch ohne Jack der in Cadence intergriert ist?
Aber wie? Ich würde mich sehr freuen wenn mir Jemand auf die Sprünge helfen könnte.
Liebe grüße Knaeby
habe mich ehrlichgesagt noch nicht mit midi unter ardour 4 beschäftigt, also nicht viel...
hast du midi überhaubt schonmal am start gehehabt?
also in z.b. seq24?
Knaeby
Hallo Corresponder,
ja unter Ardour 3 lief Audio/Midi einwandfrei.Wenn ich jetzt Ardour starte kommt diese Fehlermeldung.
Konnte nicht zur Audio/Midi Engine wiedervervinden
Was heist das und wo muss ich etwas machen. Grüße Knaeby
jackd wird wohl die audio/midi engine sein.
hast du qjackctl laufen?
Knaeby
Hallo khz, Mitsch, Corresponder und wer mich noch hier sieht.
Ich habe 2 Probleme: Jack in Cadence bekomme ich gelegentlich arbeitsfähig. Aber ich habe noch immer nicht festgestellt wann er stabil läuft.Gibt eine zwingende Einstellung?
Läuft er kann ich nicht feststellen wie ich in Catia die notwendigen Verbindungen zwischen Ardour meinen Periferiegeräten und zB. SynAddSubFix herstelle.
Könnt Ihr mir eine Anleitung zusenden wie ich beides bewerkstelligen könnte, oder mir zeigen wie ich meine Einstellungen in einem Bildschirm Foto an Euch übersende.
Liebe Grüße Knaeby
Von Psychotronic auf sequencer.de: Link Linux Audio - Der KXStudio Stack mit Jack
Video: http://psychotronic.electronicattack.de ... audio.webm
Die ersten 27 Minuten erklärt er das Cadence, evt. ist das hilfreich.
Ich hatte nie kxstudio / Cadence ..., sry.
Sollte aber doch so sein das du deine Soundkarte auswählst und gut.
Zu Ardour4 & Midi hab ich schon was geschrieben. Zur Not starte ein/mehrere testsessions und versuche verschieden (Gedanken)Routings (Verbindungen) aus. [Meta]Versuch/Irrtum Ding.[/Meta]
IRC - wenig los aber schau ab und an vorbei.
Psychotronic hat auch ein Video zu der Distribution gemacht => http://www.sequencer.de/synthesizer/vie ... 7#p1157217.
Im Video ab ~5.00 min:
Bei "Pulseaudio Volume Control" keine Soundcard auswählen, reboot.
In Cadence "Force Restart" drücken,
jack starten.
Jack-Bridges installieren falls noch nicht vorhanden und "ALSA -> PulseAudio -> Jack" auswählen.
"ALSA MIDI Bridge" starten (in qjackctl nutze ich a2jmidid, dürfte also ein Paket in der Art von a2jmidi_bridge sein).
PulseAudio starten.
Documentation:Manual:alsa_and_kxstudio
Documentation:Manual:jack_configuration
Ardour4 && MIDI kann ich leider nicht viel mehr dazu beitragen, da ich es selber kaum nutze für MIDI. Ist aber umständlich laut Netz bzw. evt auch noch nicht so ausgereift, keine Ahnung.
Evt. ist für MIDI qtractor besser?
http://www.linux-community.de/Internal/ ... n-Qtractor
Knaeby
Hallo Ihr Lieben,
mit KXSTUDIO haben sich meine Verständnis Probleme so gehäuft, dass ich wieder mit meinen Möglichkeiten bei Ubuntu Studio " eingekehrt" bin, und sogar gerne! Nach dem Sprichwort < Schuster bleib bei Deinen Leisten >
Nach einer Neuinstallation von Ubuntu Studio habe ich alles so einrichten können dass ich gut arbeiten kann.
Wenn ich mit Ardour 3 arbeite kann ich wie es sich gehört alle Arbeit " hören".
Ubuntu Studio ist ja auch ein B.S. und deshalb muss ich auch CDs DVDs und Videos aus dem Internet sehen und hören können. Seit der Neuinstellation streikt Ubuntu hier komplett,warum? Mal wieder brauche ich Hilfe um diesem Mangel abzuhelfen.
Muss dass Soundsystem an Bord des PCs abgeschaltet weden, weil ich mit Ardour über mein Audio Interface arbeite, und wenn wo und wie mache ich das? Ich denke hierbei kann mir weiter geholfen werden? Es ist wohl in der Grundeinstellung von Ubuntu Studio eine Einstellung vor zu nehmen, die dann allen Ton über mein Audio Interface routet. Liege ich damit richtig?
Liebe Grüße Knaeby
Ps: Vielen Dank dass Ihr mir bei meinem Ausflug in die "Höhen" von KXSTUDIO so engagiert geholfen habt.
KXStudio war ein Versuch, hätte ja auch alles auf Anhieb klappen können. Nur durch Versuche lernt man.
Zu deinem Ubuntustudio Problem:
Schau dir mal die Artikel an, evt. ist da was hilfreiches dabei: >> https://wiki.ubuntuusers.de/Soundkarten <<
Zeigt dir an welche Soundcard im Computer ist
cat /proc/asound/cards
* Ist da Pulseaudio (Pulse) im Ubuntustudio installiert?
Da kann ich nicht wirklich helfen da ich immer ohne Pulseaudio mein System baue.
Hat jemand anders einen Tipp (gibt es überhaupt noch user auf a4l.de?)?
* Läuft qjackctl wenn du "CDs DVDs und Videos aus dem Internet" hören/sehen willst?
Wenn qjackctl läuft wären zwei Möglichkeiten:
1) Stoppe qjackctl
2) >> https://wiki.ubuntuusers.de/.asoundrc#Direkt <<
nano .asoundrc
pcm.jackplug12 {
        type plug
        slave { pcm "jack12" }
pcm.jack12 {
        type jack
        playback_ports {
                0 alsa_pcm:playback_1
                1 alsa_pcm:playback_2
        capture_ports {
                0 alsa_pcm:capture_1
                1 alsa_pcm:capture_2
Zu Ardour/MIDI:
khz hat geschrieben:Ardour4 && MIDI kann ich leider nicht viel mehr dazu beitragen, da ich es selber kaum nutze für MIDI. Ist aber umständlich laut Netz bzw. evt auch noch nicht so ausgereift, keine Ahnung.
Ich bekomme da (Ardour) auch nicht schnell/intuitiv/... was hin und stürzt auch ab und an ab. Bist also nicht alleine. ;-)
Deswegen evt. auch mal Qtractor anschauen (welches ich selbst aber auch nicht nutze ^^).
Knaeby
Hallo khz und andere,
ich werde erstmal zeigen was in meinem PC an "Sound" eingerichtet ist.
hans@hans-System:~$ cat /proc/asound/cards
 0 [Intel          ]: HDA-Intel - HDA Intel
                      HDA Intel at 0xfcff8000 irq 30
 1 [Omega          ]: USB-Audio - Lexicon Omega
                      Lexicon Lexicon Omega at usb-0000:00:1d.0-2, full speed
 2 [XT             ]: USB-Audio - ESI KeyControl 49 XT
                      ESI ESI KeyControl 49 XT at usb-0000:00:1d.1-2, full speed
 3 [Interface      ]: USB-Audio - USB MIDI Interface
                      USB MIDI Interface at usb-0000:00:1d.2-2, full speed
 4 [NVidia         ]: HDA-Intel - HDA NVidia
                      HDA NVidia at 0xfe8fc000 irq 17
hans@hans-System:~$
Das ist der Gesamtbestand.
Das ist mein Audio Interface.
Das ist mein Keybord.
Mit diesem Gerät spiele ich mein < Yamaha WX7 > ein Blaswandler, ich kann damit wie auf einem " elektronischem Saxophon" Midi Instrumente einspielen.
Alle diese Komponenten brauche ich um mit Ardour Musik zu produzieren, und das Klappt einwandfrei.
Das sollte die on Bord Audio Card des PCs sein.
Dieser Eintrag ist erst aufgetaucht seit mir eine neue Grafik Card im PC installiert wurde.
Soweit meine Übersicht, ist alles aktiv, und entstehen Inkompatibilitäten durch die 3 Sound Systeme? Wie kann ich weiter vorgehen?
Ich will erstmal nichts Neues hinzufügen bevor wir nicht genau wissen was bei mir sein darf und was nicht!
Liebe Grüße Knaeby
Die Lexicon Omega
Knaeby hat geschrieben:
ist deine Sounddkarte, die du immer nutzen willst?
>> https://wiki.ubuntuusers.de/Soundkarten ... rten-ndern <<
cat /proc/asound/modules
Die mit " Lexicon Omega" dann wie im Ubuntu Artikel in "/etc/modprobe.d/sound-cards-order" eintragen.
# HDA NVidia (HDA-Intel) taucht auf da diese evt. auch sound ausgeben können (Bildschirmboxen bzw. Intel onboard Soundcard).
Übrigens da ja mehrere mit USB-Audio bezeichnet werden (in "cat /proc/asound/modules" dann auch?)
hans@hans-System:~$
solltest du beim Rechner Start nur deine Omega eingeschaltet haben, "ESI KeyControl 49 XT" und "USB MIDI Interface" erst nach dem Anmelden im Ubutustudio (das beim booten nicht mal zufällig sich das "ESI KeyControl 49 XT" als Soundkarte einschleicht).
Auch da solltest du nachschaue (Konsole) ob in
cat /etc/security/limits.conf |grep @audio
sowas wie
@audio		-	rtprio		99
angezeigt wird. Steht da die @audio Einträge, dann ist das gut.
Wenn nicht:
sudo bash
echo "@audio		-	rtprio		99" >> /etc/security/limits.conf
echo "@audio		-	memlock		unlimited" >> /etc/security/limits.conf
Allgemein noch:
>> https://wiki.ubuntuusers.de/Ubuntu_Studio <<
>> https://wiki.ubuntuusers.de/Tonstudio <<
>> http://www.ubuntu-musiker.de/ <<
Mitglieder in diesem Forum: Ahrefs [Bot] und 1 Gast
